Hi
I am installing a towel rad, the pipes are already there ready and valve fitted, pls see pics. I have fitted required parts to the rad, pls see pics.
I have looked on you tube but all in all vids they first fit the rad on the wall then do the piping which don't apply to me. I bought rad with same spacing between pipes as the rad I had before.
1. The first issue is rad bracket depth to wall. I have the 4 brackets on rad, as in pics they are about 70mm from wall but valve centre from wall is 40mm as in pics. So I need to cut the bracket by around 35mm? I will have to cut both parts of each bracket, pls correct if wrong? By Hacksaw?
Also need to make hole for small holding screws, drill will break the plastic I guess, what's the best way?
2. As pipes are ready, what's the best way to measure brackets locations on wall? Is it best to cut the 4 brackets, assemble them on rad, place rad on the two valves and pencil 4 brackets locations on wall?
How much to allow for the nut which connects rad to the two valves? Or may be I don't need to allow anything as rad sits on valves and tightened? I don't need PTFE or Jointing compound here as there is washer.
3. It's plasterboard wall, which fixings is recommended?
TIA
TIA
