It is true that the risk of an EV self igniting is about the same as the risk of an ICE vehicle self igniting
Iirc, it is about twenty times less likely
I've read something similar.Iirc, it is about twenty times less likely
Currently it's mostly gas, which is because that is what we have available.Agreed, but what did they have to make use of, when the wind didn't blow?
The usual trap of 'if it's not 100% perfect in every way we can't use it'.If the wind always blew, and wind generation always generated at 100% of its maximum design capacity, then I would call it viable.
Is it?It is true that the risk of an EV self igniting is about the same as the risk of an ICE vehicle self igniting.
100 tonnes @ 26m = 7.1kWhTranslate that storage to a concrete block power storage, and a guess of the top of my head - a 100 ton block, raised to the height of a tower cranes, might generate 7Kw on the way down.
Now there's an idea. I reckon a small bungalow is about 100 tonnes, so maybe we can have a system where we winch the entire house up in the air overnight, get a great view in the morning, and then the fall provides the energy for the day![]()
Being first, involves massive early adopter costs, and few benefits. Then soon, something better comes along which is better, more efficient, and cheaper.
Agreed, but what did they have to make use of, when the wind didn't blow? If the wind always blew, and wind generation always generated at 100% of its maximum design capacity, then I would call it viable.
Not having an EV or an inverter on a changeover switch, or any power-exporting apparatus I'm not familiar with the terminology.
What about a rail gun?
Don't tempt the green eco zealot enviro fanatic tree-hugging carbon neutral nazis. They have enough crazy schemes of their own.
If you investigate the graphs, and look at the windmills, the weather - then wind and amount of sun, are very variable. Not a problem if our consumption could vary to suit, but is cannot. That's why we have to provide expensive backup. The backup cannot instantly come online, so we have it running, and ready to pick up the load. Running and ready, consumes almost as much as it would, when the capacity is used on the network.
So the cost of green generation sources, is the cost of the green sources + the cost of running backups.
I feel like you're not quite getting my point or you're bringing past experience from "how things were done in power generation" in inappropriately for the point I'm trying to make..
We want to use energy because it's fun, and there is all this energy kicking around in the environment and we are constantly working out ways to harvest it. A coal power station running your laptop so you can have fun posting on DIYnot is purely a conversion device harvesting stored energy from coal which came to be from millions of years of vegetation being a conversion device storing energy from the sun. Capturing energy while it's available in one form now and storing it in something that we can later process to recover some of it later is an idea as old as the earth, more or less
There are huge inefficiencies in that approach, but traditionally we (primitive man) didn't really appreciate it, and it didn't matter because there weren't enough of us for the waste to pile up noticeably
Now, there are a lot of us all wanting to use energy to have fun, and we need to be a lot more focused on doing more with less rather than just finding more ways to produce more so that we can consume more - that means using less of it, and losing less when we convert it.
One day there probably won't be this notion of "20 million people switch a kettle on during the corrie ad break, get that coal power station revved up an hour before so that all those muppets can just carry on flippantly burning energy like they always have", it'll be more like "electricity during the corrie ad break costs £5000/kWh, if you want to pay £150 for a cuppa go right ahead, or invest in some storage system that means you can make it through the wind lulls and still have your cuppa. Or forego your cuppa"
Energy generation/demand mismatches will always occur, but there is always something that can be done to mitigate, and that may include human compromise
The differences are
(1) how to extinquish the fire
diesel and petrol fires can be extinquished by preventing thier access to oxygen
lithium batteries produce their own oxygen so cannot be extinguished by conventional methods.
(2) radius of damage / harm
diesel and petrol fires create an area where high temperature air and/or liquids are the only hazards and these can be managed.
lithium batteries can eject material at high temperature and high velocity ( red hot bullets ) over a large area.
