Upgrade or renew existing system?
8 Mar 2015
Surrey
Good morning. I currently have an Optima Compact G4 alarm system; the system still works great, but the two external bell boxes require replacement (covers have crumbled, etc.).
My question is, do I replace the existing system with something new (preferably hard-wired) or keep the current system and replace the external bell boxes?
That's what I have on mine but the Ody 1 or Ody 2 are available for the usual vertical or horizontal boxes. The Ody 3E is quite loud on my house but this may be due to the ocation of other houses around me. If you need to have two sounders then the second would need to be SCB as the power supply will not cope with two sounders.
The panel you have does not have tag capability
Thank you! I assume the Odyssey 3E has SCB mode? Ah, yes, it does, so one sounder will need to be on SCB mode and the other on SAB?
As per PM fit a backlit bellbox …..either pyronix or texecom ….
this will do? I would however need to buy a cover separately.
When I started fitting alarms, most domestic panels didn't have enough grunt to run two live external sounders (or the other way to look at it was that external sounders were power-greedy, taking up the vast majority of the power output of the panel).
If you wanted two, you had to fit an aux PSU.
ah interesting, is this easy to fit?
Looks right - you can get complete sounders but the price is usually about the same as backplate + cover
