Worcester Bosch Si Compact 30 Kw
7 rads + towel rad
Roughly 8-9 kw rad output
Ok, I keep hearing all the talk of trying lower flow temperatures and seeing the advice about trying different lower temperatures to see if your system would heat up ok with them.
So, I thought I'd try at 48c and work my way up.
Running Nest our schedule is
0715 to 1730 18c
1730 to 2145 19c
2145 to next day at 16c setback
Now I know it's not been particularly cold (apart from the odd morning at 5c) but find ours is getting up to the set temperatures in our 1900s built house.
The boiler sometimes does hit set point (48c) +5 then wait to cool to the hysteris. Is this harming the boiler? Should it be set higher so it hits the room temp before hitting the boiler set point temp?
I have balanced all the rads at around 12c but when looking at the boiler return (it actually shows the temp), it is only about 8c from a flow of 48c
The pump speed is on 2, speed 1 didn't seem to get the water around fast enough and speed 3 was too quick, and reached the set point as it does now (but earlier).
Maybe I've done all the rad/room calculations right (pure luck if so as certain sites give different powers needed) and the rad output where the room stat is gives out a max 2.2 Kw whereas with the current temp only about 800 watts is need, hence the low flow temp.
Thought please, especially about the boiler hitting set point +
7 rads + towel rad
0715 to 1730 18c
1730 to 2145 19c
