Hi. I'm trying to resolve a problem with a 9 year old Potterton Precision boiler.
The problem is that it sometimes just doesn't start up when the controller calls for heat or hot water. There are no faults showing - the three diagnostic LEDs are dark - but there is power to the boiler. Generally, however, if I turn it off at the isolator then back on after a few seconds it will work fine, and will continue to work fine for some time - many hours or a day or two. But after being idle for a while the problem can kick in again, and another restart is needed.
The next step would be to get a refurb PCB, but is there anything I should try before that?
