D
Deleted member 317777
The truth is, engineers don't need to gain access at all
For a SM the above is true.
No warrant for entry needed on a SM boyo.
Not needed on my old property or on some periods of house building where the meters will be in a cabinet usually inset in the external wall of the house. That change probably came about so that they don't need to gain access.
Better idea with the quote further down.One wonders whether they will find it easier to remotely turn off smart meters or parachute in Russian gas engineers to break into houses and turn off the analogue ones?
You've really lost the plot...The truth is, engineers don't need to gain access at all, if they wanted to cut off the supply to a property. And even when they do, obtaining warrants seems to be a simple process. Courts readily hand them out. No dramas.
You take it how you want champ.I take it all the I don't want a smart meter because they can't be shut off remotely and don't need a warrant lot are just fiddling the leccy and gas so the rest of us pay more.
No doubt nosenothing will claim it's the same process
He’s been a joy in this thread.You've really lost the plot...
'The truth is, engineers don't need to gain access at all, if they wanted to cut off the supply to a property'...
Followed by, 'And even when they do'?
That means you acknowledge that the different types of meters need a different disconnection method...
You could have saved yourself an awful lot of effort/stress at the start of this topic by simply acknowledging the truth of the matter...
Although it has been a bit of fun watching you tie yourself up in knots![]()
Correct. If the courts didn't give out permission like sweets they still don't need access.'The truth is, engineers don't need to gain access at all, if they wanted to cut off the supply to a property'...
That is another risk of course...Better idea with the quote further down.
"With a cyber attack, Russia can turn the lights off for millions of people. It can shut down the power grids,"
Nonsense.You've really lost the plot...
Correct.'The truth is, engineers don't need to gain access at all, if they wanted to cut off the supply to a property'...
Correct. I have never stated anything different.That means you acknowledge that the different types of meters need a different disconnection method...
The truth....You could have saved yourself an awful lot of effort/stress at the start of this topic by simply acknowledging the truth of the matter...
Ah, so selective quoting in an attempt to defend the indefensible...Correct. If the courts didn't give out permission like sweets they still don't need access.
Nah, better to hack the grid and knock out everyone don't you think. Unless Pootin has an aversion to smart meters as well of course...But better for them to hack into the smart meter control system which would require far more resources to restore supply.
Nonsense.Ah, so selective quoting in an attempt to defend the indefensible...
