- Joined
- 26 Nov 2024
- Messages
- 7
- Reaction score
- 0
- Country
Hi can anyone tell me what type of gas regulator this is as it doesn't fit the standard calor gas butane cylinders. What gas bottle do i need for this regulator? Thanks
Is it a fire sold in the UK?
This could be Spanish but no idea here are some markings....A picture with the markings / maker name of the reg might help?
UK:
Butane clip on can be 20mm or 21mm.
Propane clip on (aka Patio gas) is different again at 27mm.
Gas bottle regulators guide | Flogas
Not sure which propane regular you need? Want to learn how to use a gas bottle regulator? Read expert advice on gas bottle regulators here at Flogas.www.flogas.co.uk
Then there are a variety of "Continental" gas regulators... That one google lens suggests to be for Spanish gas bottles? :
Fit a UK bottle regulator in its place to the hose (assuming it's under 5 years old, if older replace the hose as well).
Guy who sold me it said it was used in a holiday home so most likely bought outside the UK.Is it a fire sold in the UK?
It's not a design that I've seeen before but, if it's a good bit bigger than your butane bottle's fitting, it could be for a patio gas bottle.
Hoses should be replaced after 5 years from first use with lpg gas*.The hose looks new or is this not something to go by? Thanks again
Even though they are not recommended for gas hoses, worm drive clips are often supplied with them.secured with a jubilee clip
