- Joined
- 12 Dec 2024
- Messages
- 14
- Reaction score
- 5
- Country
Time for a new PCB then..
That's what I suspected but was holding out hope. Damn. This is going to sting.
If that’s how it’s wired, how did you inadvertently send mains voltage to it?View attachment 365994View attachment 365995
The 12v RT is on the top left of the PCB, 240v is on the top right.
Just to add, there is no sign of scorching, smoke, etc on the front or back of the PCB but there is the smell of burnt plastics/electronics.
I replaced the hub with a Drayton Wiser unit and the CH wasn't firing (hot water was fine). After some research it looked like i needed a link between L and 1.If that’s how it’s wired, how did you inadvertently send mains voltage to it?
Different threadHope your claiming off the installer who got it all wrong?
Ebus - Vaillant and glowworm controls only for modulationThere is an OpenTherm block
He was getting confused with a similar threadRe: claiming if the installer - a) I've only been in the house a month, and b) I've given myself a stern talking to (I was installing the Wiser myself).
It can be. Depends on how long you plan to keep your existing boiler for and if you'd stick with Vaillant/Glow wormIs it worth getting the eBus connected up?
Again, I've no idea what these Bus connections are for. As a result, I've not touched it.
When I upgraded to Valliant designated controls, the boiler became less "noisy" or at least almost inaudible, at first I thought it wasn't running!Is it worth getting the eBus connected up?
Thanks.It's a control bus unique to Vaillant, though they did an adaptor which allowed it to connect to a standard bus system, it was never allowed to be sold in the UK.
Worthwhile getting the Vaillant control kit? If you think the investment in the kit, is worthwhile, if your boiler will last long enough, or you would replace it with another Vaillant - yes. The kit makes a great job of precisely controlling the boilers output, to match the load and demand, which itself offers savings in gas consumption, plus the steady heat from radiators, instead of the hot, then cold.
Yes, the Wiser would usually be replaced. However, as Harry has mentioned...Plus I've just invested in the Wiser kit so wouldn't want to waste that (it sounds like the Vaillant kit would replace the Wiser?).
The Vaillant VR33 OpenTherm adapter would be unsupported, but is available.It's a control bus unique to Vaillant, though they did an adaptor which allowed it to connect to a standard bus system, it was never allowed to be sold in the UK.
