With a gas boiler able to extract latent heat from flue gases, the whole idea is analogue control, the typical motorised valve,
can only switch on/off, if there are enough of them say 10, using EPH thermostats for example, it can be close enough to analogue, and where you have an area often not required, in my case the granny flat, to turn off an area for weeks at a time makes sense, but in most cases we want a motorised valve which can gradually open or close, there is a whole list of electronic TRV heads.
each one has plus and minus features, and prices for £15 to £70 each, the best have cleaver algorithms that work out how long it takes to heat the room and can connect to a hub which in turn tells the boiler when to run, the cheapest don't connect to anything, but can be set with a schedule so room only heated when required, often using an economy setting so the room can be heated up faster to the comfort setting.
The thing is digital (on/off) will work, but analogue will use less energy, as to if enough to be worth the expense can't say, a well set up gas system can be 90% efficient, and poorly set up could be 75% efficient, but would the owner really know if they could get that extra 15%, likely not.
I look at my own devices,
it gives me a lovely graph, and the saw tooth is due to being an oil boiler, so the boiler is turning on/off all the time, if the same valve was on a gas boiler you would see a smoother graph. But the main house is basic split into 9 zones.
There are three basic methods of piping central heating, one pipe system is used in the heritage railway where I volunteer, the steam is simply released to atmosphere on the last carriage, but we have a real boiler, which actually boils the water, but with most central heating systems there are two pipes, but the water can be in series or parallel, in domestic mainly in parallel, series would work well with fan assisted radiators, but the parallel system with by-pass valves has been the method used for years, I looked at the ivector fan assisted radiator but the building management system to control it is rather expensive, and this is the problem, move away from the standard system and costs go up, we can look at all these fancy systems, but they cost.
So the first point has to be to look at the boiler, with my oil boiler, there is no point me looking at OpenTherm or anything else, but if I had a gas boiler, likely there would be some option for ebus control, but some will only work with a single thermostat, so then one has to decide if in the home your looking at, can it be made to work with a single thermostat.
My house that does not work, tried single thermostat in hall, but hall cools down too slowly, one can adjust the heat up time with the lock shield valve, but not cool down time, so at moment I have three wall thermostats, two for main house, and one for the flat.
I had to work with what I have, no real hope to re-pipe, so I am trying to make a silk purse out of a sows ear, and I have to look will spending £X on a new thermostat or TRV head give me enough improvement to be worth the cost. The system I have can be improved, and I will likely change some eQ-3 TRV heads for Wiser TRV heads, in key rooms, but since adding the second room thermostat I am using Wiser and Nest in parallel the heating has been reasonable.
