Hi
From reading around, I understand that the recommendation is for an isolator to be 2m away, this is to avoid someone in the tub being able to access the isolator.
See photo. Circled is where the 32AMP supply comes to.
This is also the exact spot we want to put the hot tub.
Grateful for recommendations of where we can put the isolator. Can it stay there, is the 2m figure just a recommendation, rather than a rule. If it it below the height of the tub, with a 20cm gap and an IP67 rated isolator.
