- Joined
- 15 Nov 2018
- Messages
- 204
- Reaction score
- 13
- Country
I’ve recently discovered, that a single socket outlet in my kitchen, which I intend to plug a washer dryer into, which currently also supplies power to my fridge freezer, had been converted to a surface mount double socket, apparently the tenant before had separate under counter fridge & freezer.
The double surface mount back plate actually fixes around the existing singe socket and is screwed onto the original single socket backplate and the double face plate affixes as normal.
The consumer unit trip switch is rated at 32 amp for all the sockets in my property, two of which I use for electric heaters.
Would it be safe to use this surface mount double socket to power my fridge freezer and a washer dryer, without overloading the circuit ?
