We've just moved into a bungalow which has a fairly old central heating system. A Potterton Prima F boiler, a Landis & Gyr RWB2 controller and no room stat all, the radiators with the exception of the bathroom have mechanical TRV. My first thoughts were to perhaps change the controller for either a Honeywell ST9400C or a Lavatap Pro which advertises itself as a direct replacement for the Honeywell and to fit a WiFi room stat such as the the Netatmo with the thought of sometime later swapping out the TRV for the WiFi heads.
First oddity is I have only 4 connections in the backplate for the controller Live, Neutral, 3 & 4 https://www.dropbox.com/scl/fi/5wv3...late.jpg?rlkey=xa3yqqau96rvsubc4zaxq0l8j&dl=0 I was expecting to find something on #2. I figure I could interrupt #4 take out via a junction and through the contacts for a thermostat and that should work. But the modern controller I am unsure and which order to swap them. If I understand correctly the backplate should be common so a drop in replacement for the controller?
There's a junction box in the loft but it is a mess, I am up for tidying it but not in the winter and risking breaking the heating. There's a 3 port valve and two 2 ports plus the shower pump tacked in there. There's 2 hot water cylinder linked together and 1 stat on the left side one https://www.dropbox.com/scl/fi/zl84gr8w09qjjfyb7gb03/Tanks.jpg?rlkey=6mzh3d4ff6dgzn6zyaqe02md5&dl=0
I did open the boiler but again the wiring is a bit of a pickle, nothing is clearly marked,
