Any definitive guidance out there on RCBO spacing, just going through some quotes for a flat referb, one has a note on it specifying that a 12 way board was needed to correctly space out the RCBO's to minimise " overheating and fire risk"... the two others spec a 8 way board ( its a tiny flat)
Is this something new ?
the last one we had done was installed with no spacing but the rcbo's were installed in a mix ie 32amp,6amp,32amp,16 ,,, as that electrician said they should not be ordered traditionally largest to smallest along the busbar to minimise heating but said that was to prevent unwanted tripping.
Any regs out there or is this just a case of I fink...
