Hello,
We have moved into a 1920s Semi and was surprised to find that the upstairs bedroom window has been fitted into a wooden frame and is not supported by any brick underneath. This is how it was built much like bay windows being located in timber frames between floors. I'd like to replace the window as it has bowed badly and the frames have distorted so that the windows do not shut properly. It's also letting the cold in as you can imagine. What you can only just make out in the photo is either side of the window at the bottom is the ends of the brick wall (solid brick) come in and finish just below the corners of the window on each side.
The previous owners built an extension which led to the window directly below being removed but I'm not exactly sure what remains under the wooden boards under the window from the outside. (see photo) I'm a bit afraid to remove them until such time as we are ready to take action.
I'm getting window fitters to come and quote on a replacement as I'd like to insulate and replace the frame but I can't work out how exactly you can fit a window into the current opening and have it supported properly so it doesn't bow again. Can you suggest what can be done?
