Hi folks,
I want to ‘sanitise’ the walls of an ancient (and neglected for decades) rear extension to a house (used as a utility room/’scullery’ and a toilet. The walls (‘dry’and fairly flat) are currently simply painted (probably umpteen generations of coats!) brickwork. There clearly are many possible options, which include:
My plastering skills, although ‘not too bad’, are limited, so I think that (1) is probably a non-starter and, of the rest, 2(a) would probably involve the most work/time.
What would you suggest as the most ‘painless’ approach for a non-professional? Are there any other approaches I’ve overlooked? I imagine that most of them would probably need the walls to be PVAd or suchlike.
1… Plastering all the walls
2… Install plasterboard by:
. 2a…fixing to battens
. 2b…’dot and dab’
. 2c… adhesive foam, or even some sort of grab adhesive
