Wiring design for Attic rooms.
14 Dec 2011
Dorset
Hi, just looking to get some advice on the lighting circuit for my house. Basically ive built two new bedrooms in the attic and was thinking of the best way to wire the lighting circuit for this level of the house. I will be getting a professional in of couse. But would there be an issue with this design. If I have a panel in the ashlar space that easily accessable. On this panel there would be a wago junciton box for each room where a feed goes up into the loft space and then to each lighting swtich for each room where the lights are setup up with standard 2 plate method for led ceiling downlights. I could then connect each wagobox on this consumer panel in a radial cirucuit on this consumer panel where a feed goes off to connect to the consumer panel. Just thinking if anything goes wrong in the future or I want to add/ troubleshoot issues its all easily accessable. Can anyone see an issue with this concept in principle. Ive added a basic plan in case what im describing is not clear..
Blue box is a seperate wago for feed coming off the MCB. Just to seperate everything.
Why not leave it to the spark.
I detest customers who try to tell me how to do my work and get charged more accordingly
Becuase if I can do the donkey work and run a few cables which could save me a few quid I will. I wont be hiring an electrician that charges me more for asking a question either so no worries there.
I recommend you find a local spark pdq
Are BCO involved
Why so you can tell me that im not allowed to run a few cables? Im just trying to get an idea of cable routes so I can preplan things like celotexing. Your just here to troll, so if your not going to add anything then please go lay some cable somewhere else.
Oer , bit tetchy are we
So no BCO then
If your not going to contribute to the original question then why hijack the thread? are you bored or something.
