Hypocrite? Why?Really - is that it - is that all you got--- did you walk there from the UK - hypocrite. Sums up the climate scam.
Pointing out your inability to understand basic science, makes me a hypocrite? How?
Not only are you the forums hypocrite you are also the forums squirming worm - well done - stupid on two levels.Hypocrite? Why?
I guess you either don’t understand the question or you don’t have an answer. Which is it?Hypocrite? Why?
Badass always.What about the far left delusion? Equally as bad if not worse.
I am sorry Aveatry but that is factually incorrectwater vapour are far more involved in climate change
Aveatry, methane is not a major factor in climate change.Methane and water vapour are far more involved in climate change that Co2
So if you dont accept that you are a hypocrite then you are a magnitude worse than that because whilst at the same time of believing the CO2 nonsense you are actively contributing to it more than any other forum member with all of your unnecessary flights to go skiing.I guess you either don’t understand the question or you don’t have an answer. Which is it?
The fact that I understand some of the science behind climate change and I question the morons that don’t, makes me a hypocrite?So if you dont accept that you are a hypocrite then you are a magnitude worse than that because whilst at the same time of believing the CO2 nonsense you are actively contributing to it more than any other forum member with all of your unnecessary flights to go skiing.
Aveatry, this is an extract from an article talking about growing in greenhouses.You do know that we are dangerously close the earth to not have enough CO2 to sustain plant life.
The ambient level of CO2 in the atmosphere is approximately 400 PPM. At 100 PPM of CO2 the rate of photosynthesis would be stopped completely. At 150 PPM the plants begin to respire, and photosynthesis is stopped. At this low level the plant will no longer be able to obtain CO2 from the atmosphere and photosynthesis is restricted. The plant will eventually use all of the CO2 present, photosynthesis will stop and the plant will die.
The rate of photosynthesis at 350 PPM will be consistent with growing conditions outside of a controlled environment, given that ambient levels of CO2 in the atmosphere are approximately 400 PPM.
With no other limiting factors such as heat, light and nutrients the plants will photosynthesize at a rate consistent with ambient conditions (i.e. outside of the greenhouse). There may be a slight increase in photosynthetic efficiency due to the higher than ambient CO2 level, however this increase will probably be insignificant. The level of 1000 PPM CO2 is very close to the optimum level of CO2 required, given no other limiting factor, 1200 PPM, to allow a plant to photosynthesis at the maximum rate.
Aveatry has taken that from an article on greenhouse growing.Where are you getting your info?
What is the far left delusion?What about the far left delusion? Equally as bad if not worse.
Don't be silly now.What is the far left delusion?
The far left believe public services should be publicly owned - is that a delusion?
The far left believe that minority groups should be supported not used as political footballs - is that a delusion?
The far left think that the state should provide a safety net to help those that are vulnerable: like the disabled -is that a delusion?
Don't be silly now.
Not just far left that believe public services should be publicly owned, so that's your first example dealt with.
The far left use minority groups as a political football just as much as far right and anyone between. So that's that one dealt with.
If you think it's just the far left that support a safety net for those genuinely in need, then I know who's deluded. Clue, it's not me![]()
