Stealing old threads is against the forum rules.hi I'm getting new boiler install combi to remove the old cylinders but pipe is 15 and engineer say he needs to upgrade supply to 22 so is it needed???????
If it’s been pipe sized correctly and he says it’s needed, then chances are it’s needed.hi I'm getting new boiler install combi to remove the old cylinders but pipe is 15 and engineer say he needs to upgrade supply to 22 so is it needed???????
Not entirely sure what this means. As suggested, it might be able to be run a different route.the floor is concrete so mean he will have to dig up floor which is vinyl so not interested invor
Ditch the idea of a combi and the issue goes away.hi I'm getting new boiler install combi to remove the old cylinders but pipe is 15 and engineer say he needs to upgrade supply to 22 so is it needed???????
i will ask the enginer to see what he say but thank youNot entirely sure what this means. As suggested, it might be able to be run a different route.
Tell me what you're getting at with "childish behaviour" and I'll tell you what I meanfixitflav what you mean? childish behavior
when i say for advice give good advice but you said rude way to ditch the new boilerTell me what you're getting at with "childish behaviour" and I'll tell you what I mean
It wasn't meant to be rude, you asked for advice and mine is keep the existing system and renew the boiler, unless there are other considerations like state of the cylinder etc, which we don't know about.when i say for advice give good advice but you said rude way to ditch the new boiler
I don't know where you get that from. Combis tend to be 28 - 34kW, vs heat-only typically 15kW.System and heat only tend to be higher outputs
