I need advice on a 3"x2" suspended ceiling which did not need building control. The wooden framing was done in a corner of a 'to be' kitchen boarded by 2 load bearing walls and 2 steel beams. Idea was not to attach the CLS timber to the steel beams (to avoid weakening the steel beams) and to put the wooden framing at the same height as the steel beam so I can plaster over as one later.
3x2" CLS timber was screwed using masonry screws (7.5mm diameter x 150mm long) spaced at 60cm intervals onto the 2 walls. CLS timber was hung vertically directly down from the ceiling (attached to ceiling using a joist hanger) at 60cm intervals adjacent to the steel beams with horizontal CLS timber under the vertical timber to form a rectangular frame. Then standard 60cm timber spacing screwed (standard screws) with 18mm plasterboard screwed upward. There was a 20cm gap between one horizontal timber and a steel beam so I spanned the gap with 20cm timber (which is hung separately from the ceiling using band strapping).
Bear in mind this a Victorian property and there was very limited area on the existing plasterboard ceiling to attach the 3x2" timber to
Photos (pink fireboard marks the two steel beams).
e.pcloud.link
e.pcloud.link
e.pcloud.link
e.pcloud.link
e.pcloud.link
e.pcloud.link
Was this done right? Advice please
20240731_214810.jpg - Shared with pCloud
Store photos in pCloud. Share them with just the right people. Access them on any device. Create a free account now!
20240731_214814.jpg - Shared with pCloud
20240731_214817.jpg - Shared with pCloud
20240731_214818.jpg - Shared with pCloud
20240731_214831.jpg - Shared with pCloud
20250114_141305.jpg - Shared with pCloud
