Dodgy earth… well no earth at all
If I remember correctly they sent 25A thru as the test current, bad joints were shown up but also the the fizz bang crackle had the tendency to weld the joint to such an extent that it actually had a tendency to cause a weld which might have caused a bit of continuity correction as a result.
I have not seen one for a while though. Ho happy days!
That's correct, they used a transformer, to reduce the voltage/increase the level of current, and the length of time you could press the button for, was quite limited, due to the unit overheating.
My PAT tester used 25 amps, but not the loop impedance tester, but do remember a separate option which was claimed not to trip the RCD some years back so would be over the 9 mA quoted by many as being the test current.
I have remembered the report over a death due to faulty radiator and earth there were conflicting reports, on who owned the radiator.
However, any landlord who does not correct a reported electric fault is living dangerously. It would seem the correct procedure is to rehouse until fault corrected. But as it is at the moment it is hard to find rented property, and insisting could result in being homeless.
With the Thirza Whittal case, reading the BBC report, it seems she was well aware there was a problem, and had reported it to Hilary Thompson, and one wonders when aware there was a fault, how she got a shock? In some reports, one can see how the error was made. But for this woman, some reports have her stepping into a bath and other touching a radiator.
A faulty electric-powered, oil-filled heater and a lack of earth bonding under the enamel bath combined to turn the metal bath taps into a live electrical conductor.
1740407616498.png Yes does not look like an oil filled radiator, when it first hit the headlines it as stated the oil filled radiator belonged to the tenant, but it seems any landlord - tenant situation, it is often blamed on the landlord and any factors due to tenants action are glossed over.
Most likely, a stock photo of an electrical heating device, rather than the actual device involved.
HUH all report any heating device, fixed to the wall, as storage heaters.
You are likely correct, I know I had problems with oil filled radiators, the thermostat at the end was held by two studs, and on PAT testing, they often failed.
But at home I have never bothered PAT testing or other testing, unless I have worked on it.
Yeah they did. Couple of circuits needed cpc running as cables rather than using the dodgy old conduit. RCD now working. To be fair the landlord was great. People are just scared to talk to landlords in London because they think they will be seen as expensive trouble makers and then get booted out or the rent raised to unaffordable levels. I practically had to say ‘one of you might be killed’ to get her to report this and even then her flatmates were ****ed with her !! What a world
Just wanted to say thanks to everyone for their responses. Landlord was quick to react - electrician confirmed that there was no effective earthing via the conduit or any other method for that matter. New cabling run and tested. All safe and sound !
The current EICR given to the OP should have flagged this issue
