D
Deleted member 310928
If that's the case then that wouldn't bring up an issue. Years ago, someone did similar but got the CPC from the cable and earthed it to the pipe. Not knowing where the pipe lead to he never knew if the pipe really formed part of the protective earth. One day he drilled through the pipe (not knowing it was there) the live touched the earth but never tripped anything because of the pipe not really being connected back to the MET. Later he reported he was getting tingles from the bathroom walls. At the end of the day, there is no need of running the cables through the pipe. If there is then would all other cables need ripping out?I presume the OP was talking about connecting the pipe to a CPC - which,in turn, would be 'connected back to the MET'.
