I was assuming meant wall thermostat. Thanks for the explanation. I'm not sure if we'd benefit much by having wall thermostats in each room and i prefer to keep it simple. We have a gas fire in the living room which is drawing the family to use that space together more which is nice, rest of house cooler which saves money. Can't have the thermostat in the living room of course as you say with alternate heating. Or the kitchen. We also don't have another room without external door. Hallway heat goes up so seems a poor choice.It depends on what you call a "room thermostat"?
Individual TRVs as you say seems fine and a boiler on a timer just modulated by the return temperature rising when the TRVs are shut. Its what we're doing now. Can bring the max temp of the boiler down as it gets warmer season so its a more steady heating. Seems very simple but will take a good bit of time to get perfectly balanced and set up I guess. Will be a new law in the house that no one fiddles with them without first consulting me about it. I'm not even sure if the TRVs work still, most are ancient and covered in paint and dust. On my list of things to do, just been assuming will change all of them
Once its set up best i can I'll assess if the rads would benefit from being more effective convecting ones. There's nothing in the way of sludge in the system, they are all singles and old but then maybe having ones that give off the heat more quickly would have a drawback in causing more of this
