Morning all - bit of a random question here but I've got a greenhouse that is sat on a base of scavenged offcuts of pre-stressed concrete beams. Lengths are ~650mm- 900mmIts on an allotment so the obvious poured concrete base/foundation is a no-go.
I've got them all set and levelled, the greenhouse frame is now on top and the glass going in. I have put in a couple of fixings to stop it literally blowing away (live near the coast!) but on using brown rawlplugs (7mm hole) it has caused the side of the beam to blow out a bit (although the anchor still seems to be holding. I had to drill off centre to avoid the reinforcing bar in the beam.
What's peoples views on an alternative fixing - I'm thinking either:
1) Concrete screws - am i right in thinking they don't put as much expansive force on the material as the threads cut into the concrete?
2) Chemical fixing - obviously this would work but is probably overkill and ££
