- Joined
- 18 Apr 2022
- Messages
- 6,673
- Reaction score
- 992
- Country
And at just before that he sent this message:
And I wondered how much they were.My goodness !<frightening price>
A dicky bird is a word. I think you mean 'scooby doo' - clue.Clearly someone that has not got a dicky bird as to how electrical things work.
Indeed - and one could argue much the same for virtually any tools, kitchen utensils or many other things.You could argue that a really sharp chef's knife is dangerous because if you grab the wrong bit it will hurt you badly.
Ahhh so I need to swap the plugs over. That’s cool cheers for the info and I’ll get right on that. I had no idea as I I’ve been using them for years as they are with no problems. So basically I don’t need the white cables? Just use the 3pin plugs from them and put them onto the black cables? Cheers
I have encountered that format several times over the years, starting at school, in our metal/wood workshops was a home made blueprint copier, basically a box with a curved perspex side containing a light, 2 sockets - the elderly 'inlet' was a 5A BS546 and the second was a much more recent 13A for a vacuum cleaner (to suck the print and the copy blank tight to the perspex). The widowmaker supply cable having 5A and 13A plugs.When living in Zimbabwe we used to go to French film nights at the French cultural centre, the projector was wheeled in on a trolley with a 4 gang extension block screwed to it (no lead), the projectionist used a widow maker to power it up. Myself & another electrical guy warned him of the hazard several times, nothing changed
edited to change wide to widow
We'll find out when they are relistedI have explained how to swap the connectors over, whether he does it right or not is another matter.
