A quick update on the shower.Any update on your problems @tfspark ?
Friday to check gas rating and to see if there is a heat transfer problem.
Not sure how “the plot thickens”. If you’re referring to the replacement gas valve that was done over three years ago. I had a few problems with the boiler in the first year and had to get Intergas to repair under warranty. They were the only ‘professionals’ I could call on.
I’ve alway thought from day one that there wasn’t enough hot water at the bath. All this has only come to light because the Mira engineer suggested the boiler wasn’t producing enough hot water.
You say “if” there is a fault. That’s the whole point of the thread. I’m trying to establish if there is or not.
Maybe my smart shower is not as smart as I thought it was.
Thanks dialio, point well made. I was a service engineer for 40 years in a different industry. Nothing like experience to make up for the lack of information sometimes.I merely meant that, in order to properly diagnose a fault, we need all the facts... Without being there, we have to rely on what posters put in their messages!
Even the most insignificant red herring can completely change the fault identification...
it's well known that you have to ask customers what the symptoms are, and then use experience to syphon out what's relevant and what's not - and that's when you're on site!
It involves some psychology which we never get recognition for![]()
Boiler flow temperature is 60°C, if that's what you're asking?What is the boiler stat set to for the radiators?
Yes. I'd lift that to 70 tbh.rads need to get to about 55deg before convection starts occurring. Had a few customers who turned their hre's down to 40 deg on the heating side and it affected their hot water.Boiler flow temperature is 60°C, if that's what you're asking?
Did the Engineer visit you yesterday?Just had a 15 min conversation with Intergas Technical. Basically I asked the for the DHW output of this boiler and was quoted 33kW.
I then gave him my flow and temperature figures from all taps measured, which all work out to (way) less than 33kW.
I am getting an engineer visit on Friday to check gas rating and to see if there is a heat transfer problem.
Intergas engineer did visit yesterday, and was here for about two hours.Did the Engineer visit you yesterday?
