Hi I have recently had a composite back door installed, it was supplied and fitted by a company. I pay after I am happy (not paid yet), which is why I used them.
The door fitters took less then 2hrs to remove old wooden door and reinstall new one, however 1 day after the door is making creaking sounds coming from the bottom hinge hinge and now that sounds gone and its coming from the middle hinge oddly, obviously this is not normal. The company has been notified and they are investigating the matter.
But I wish to find out how I can test if a composite door is installed correctly, the correct and technical way?
So far with my limited diy skills, I have guessed 3 points......
1. The inside of the door should have even lines (3-5mm) and gaps on all 4 sides like this picture (Mine is fine):
2.I checked with a few spirit levels, tops, bottoms, sides, inner sides of frame, door, bottom cill/step and basically everywhere on the door and frame of door to make sure its level and the spirit bubble is sitting in the middle. (which it oddly is 100% fine)
Like this:
3. I saw a YT video from a door installer here, mention you can't just use spirit levels but need a Carpenters square and it should sit flush and be level in all 4 inner corners like this:
Now my new installed back composite door fails the carpenters square test
(I tried 2 different squares), it does not sit flush in the corner and the spirit level bubble is off in 2 different corners.
here is the pic:
Can anyone confirm if this carpenters square test shows a bad door installation? And is there anything else I can check myself?
Like this:
here is the pic:
