UFO / UAP
Status
Not open for further replies.
It’s all over the internet, take your pick.
Here’s something from the penn museum
It's interesting you quote that article. In there the granite holes that were drilled were very sloppy compared to modern tooling. 1cm error after 24cm?
I can't remember if you were one of the 'better than we can do now' crowd but that's an example of them falling below modern standards. Which is to be expected of course.
No, I wanted the source for your quote because I don't trust some of the assertions made in it.
The source the link shows the source.
It’s widely known, there’s plenty more sources to back up mine.
If you don’t trust the penn museum, not much I can do.
I will say you’re a bad loser.
They are just trolling for the sake of it now. If you had authenticated photos and videos they'd still deny it. Shame...
And what’s the run out with modern hand core drills then lol.
You agreed the core drill sample is still out for debate.
Who’s the real Troll….
Who gives a ****, if it were modern tools you'd use power tools. That the Egyptians were probably better with hand tools than modern tradesmen shouldn't be a shocker.
The quality of the machining is not suspicious.
Liar liar pants on fire, that link doesn't contain what you had quoted.
It isn't even an analysis of the core itself, it's a different artifact being investigated.
  1. The drilling was done entirely from one end with a relatively slight taper. Over the 24 cm. length of the drill hole there was only 1 cm. or 4% narrowing, indicating very little wear and wobble of the drill. This shape suggested the use of a tubular drill and will be discussed later.
Only “you” used the word “error”
That was sad, even by your standards. I’m disappointed
In face the part I’ve quoted states its very accurate.
The only liar is you.
Unless you’ve read the article incorrectly, you probably have.
Core 7 is famous and still out for debate.
What 'error' are you gibbering about? it's not in the quote.
The one you mentioned above!
Where you’ve tried to manipulate what was actually written.
Status
