No, I wanted the source for your quote because I don't trust some of the assertions made in it.It’s all over the internet, take your pick.
Here’s something from the penn museum
It's interesting you quote that article. In there the granite holes that were drilled were very sloppy compared to modern tooling. 1cm error after 24cm?It’s all over the internet, take your pick.
The source the link shows the source.No, I wanted the source for your quote because I don't trust some of the assertions made in it.
They are just trolling for the sake of it now. If you had authenticated photos and videos they'd still deny it. Shame...No, I wanted the source for your quote because I don't trust some of the assertions made in it.
And what’s the run out with modern hand core drills then lol.It's interesting you quote that article. In there the granite holes that were drilled were very sloppy compared to modern tooling. 1cm error after 24cm?
You agreed the core drill sample is still out for debate.They are just trolling for the sake of it now. If you had authenticated photos and videos they'd still deny it. Shame...
Who gives a ****, if it were modern tools you'd use power tools. That the Egyptians were probably better with hand tools than modern tradesmen shouldn't be a shocker.And what’s the run out with modern hand core drills then lol.
Yes, on how the Egyptians did it. There is no mention of someone else doing it.You agreed the core drill sample is still out for debate.
Liar liar pants on fire, that link doesn't contain what you had quoted.The source the link shows the source.
It’s widely known, there’s plenty more sources to back up mine.
If you don’t trust the penn museum, not much I can do.
I will say you’re a bad loser.
nwgs is a renowned troll. And proud of it.Liar liar pants on fire, that link doesn't contain what you had quoted.
I can't remember if you were one of the 'better than we can do now' crowd but that's an example of them falling below modern standards. Which is to be expected of course.
The only liar is you.Liar liar pants on fire, that link doesn't contain what you had quoted.
What 'error' are you gibbering about? it's not in the quote.Only “you” used the word “error”
- The drilling was done entirely from one end with a relatively slight taper. Over the 24 cm. length of the drill hole there was only 1 cm. or 4% narrowing, indicating very little wear and wobble of the drill. This shape suggested the use of a tubular drill and will be discussed later.
That was sad, even by your standards. I’m disappointed
The one you mentioned above!What 'error' are you gibbering about? it's not in the quote.
