Foundation blocks - medium or dense?
27 Dec 2015
Wanted a second opinion other than my own incompetent one!
I've a retaining wall that'll be 900mm above ground level, 10M wide, about 3M at the sides. Digging down with the JCB, which I'd not used before, I created a trench somewhere between 300 - 450mm wide. It's widest at the mid-point (5M) which I assume is good fortune. I was surprised how deep I had to go, I was at about 800mm in parts and still not really hitting what I'd consider hard ground, but I was also thinking about the level of work regarding the filling so didn't go much deeper. Also having no experience the depth became somewhat variable.
The foundation thus is 300-450mm wide and varies in depth between 150mm and 450mm deep (it took two long hard days of cement mixing to get it filled). There's about 300mm to get to ground level.
Being 900mm above ground level I read that I'd be stupid going for a 100mm thickness wall so am planning to go with 220mm blocks. The question is whether being the foundation is only 300mm in places and the height is only 900mm I'd be better going for the medium density 14kg (still 7n) blocks to give the foundation an easier life, but in-hope that the weight is still enough to hold back 90cm of soil. Dense blocks are 20kg.
Your expert advice is much appreciated.
I've a retaining wall that'll be 900mm above ground level, 10M wide, about 3M at the sides. Digging down with the JCB, which I'd not used before, I created a trench somewhere between 300 - 450mm wide. It's widest at the mid-point (5M) which I assume is good fortune. I was surprised how deep I had to go, I was at about 900mm in parts and still not really hitting what I'd consider hard ground, but I was also thinking about the level of work regarding the filling so didn't go much deeper. Also having no experience the depth became somewhat variable.
Anything against, in or beneath soil - dense all day.
You need weight in a wall like this so dense. Lean the wall back into the high ground rather than vertical: this will add stability
You are better off posting a plan or photos, as none of the dimensions have any context, and make little sense.
What's foundation depth? The trench depth or the concrete thickness. 150mm depth for a wall at least 1000mm high, part of it retaining?
Expansion joint for a 10m wall?
How much ground is being retained?
Etc etc.
Foundation depth = 150mm to 450mm
Foundation width = 300mm to 450mm
Foundation top to ground level = 300mm approx
Wall above ground level (rear) = 900mm
Length = 10M, sides are 3M and taper to ground level
Masonry = blocks (100mm height, 440mm width, 210mm depth)
