Hi, I have purchased a 800mm wide floating basin vanity unit Which will need wall mounting.
My question is what size screws to use for the brackets.
The wall is solid brick with skimmed plaster on top.
I have two brackets to attach to the wall each with 3 holes to hang the unit on. The vanity unit and basin weights 42kg.
1) what screws would be sensible here would the duopower 8x65 plugs with the supplied 5x80mm screws be adequate as the picture for the brackets?
2) do I need to put all 3 screws to each bracket or can I get away with 2 screws per bracket
