I suppose that, in some senses, to have each socket having it's own cable back to the CU would be the 'purest' form of a radial circuit, since all sockets would be supplied by cables 'radiating' from a single point. However, I've never seen that done and, like you, would certainly be surprised, possibly even shocked, when I first saw it.Agreed, but as i inferred myself, my first instinct would be shocked to see it, then if was the only noted occurrence I would see no problem as such.
I was about to say that I can't think why anyone would want to do that but, on reflection, I can think of one possible reason - namely if, for some reason (and I'm not sure that I can think of a 'good' one!) they wanted the possibility of more than 32A total being supplied by one circuit - i.e. multiple sockets, each supplied individually by Method C 2.5 mm² T+E from the CU, where they were all protected by, say, a 40 A or 50A (or even 63A) MCB. However, as below, separation into circuits' would usually be a far better idea (not to mention the amounts of copper utilised!).
Agreed - but in these days of CUs with many 'ways' being readily available and little more expensive tn smaller ones, it would usually be far better to have each of the rings on its own, separate, MCB/RCBO (eggs in more than one basket!)Just like my suggestion of a two or three ring circuit being one circuit and being no more hazardous than as one larger ring, in fact rather better on volt drop and Zs considerations but yet again automatically "hey what!"
