Anyone using EvoHome controls in S-Plan Plus arrangement with Opentherm?
I'm considering the EvoHome setup with a new boiler upgrade (Baxi 800 System 2 boiler?).
We have S-Plan Plus - x2 CH zones, x1 HW; with an unvented cylinder - Santon Premier Plus 250L (PP250B).
Having investigated the EvoHome setup, I understand one needs the EvoHome Hot Water Kit (ATF500SDH) allowing the Evo system to control the HW.
thesmartthermostatshop.co.uk
The kit comprises of a battery cylinder thermostat sensor (to monitor HW temp); and a wireless relay which i believe gets wired to the HW zone valve along with the thermal cut out stat in the unvented cylinder. The existing cylinder thermostat likely gets bypass or replaced the thermostat sensor in this kit?
The kit appears to come with a insertion sensor, but i have no idea how you would install this on the unvented cylinder - Santon Premier Plus in my case?
The cylinder is fully encased plastic, and there isnt any obvious slot to attached the sensor.
Anyone have direct experience in the installation of such sensor for the Santon?
If anyone who is using a EvoHome in Opentherm/S-Plan Plus, then please let me know...
Cheers,
Hung
Honeywell Home Evohome Hot Water Kit (ATF500DHW)
Honeywell Home Evohome Hot Water Kit (ATF500DHW) | Buy Honeywell Evohome Products From the Smart Thermostat Specialists @The Smart Thermostat Shop
Cheers,
Hung
