It would have been more of a cloning than a reincarnation, since we were both here simultaneously for many yearsDon't I remember someone asking if you were BAS reincarnated. Or am I thinking of someone else.
Well this is not my first post and I have been here for a number of years. I will admit that I don't post a lot and when I have it is usually to decry some of the argumentative posts that appear on here much to the annoyance of the other participants no doubt. Surprisingly I do not have anyone on ignore because, again surprisingly perhaps, I find these combatative posts entertaining. This is probably only the second time that I have actually asked a relevant question for myself. Bottom line is that this is a do it yourself forum even though it it is called diynot and not a political mouthpiece but those posts can be entertaining as I have said. JohnW2's last line is particularly relevant.If I may be allowed a moment of nostlagia ....
... this reminds me of my very first post in this forum (here) , on 28th January 2011, after a number of years of 'lurking silently'. I did get the answer I wanted (to look for DIN-rail connectors) but, as I was fully expecting after those previous years of silently watching what went on in the forum, I got my 'baptism by fire' by being well-and-truly "BAS-ed"
Seriously though, it did make me acutely aware of the reason why some OPs whose message, like mine, starts "This is my first post in this forum" rapidly disappear and are never seen again - since they come to a forum like this for answers and advice, not to be interrogated, 'lectured' and to some extent 'accused'
That is what I thought also.I'd be pee'd off that at the site visit there was no mention by the door people that "You might want to get that moved down, Guv, before we come and fit the new door..."
I have just had a new Garador garage door fitted. I didn't realise it at the time but now that it is fitted the runners are in front of the consumer unit. The CU is not inaccessible but I now cannot shut the front cover nor can I see the fuses with getting close.
Oh my father-in-laws door was worse, the garage had no personal door, and they fitted an electric door which needed lifting to get access to the consumer unit. Had to get them back to fit a manual release mechanism. Lucky noticed before any power failure.
NoIn addition, is there not a "regulation" in the UK which stipulates that a CU must not be installed above a certain height from the floor level?
I think there is a HSE ruling, about ability to step back from an electrical box, but not in BS 7671, which most rely on to keep within the rules.In addition, is there not a "regulation" in the UK which stipulates that a CU must not be installed above a certain height from the floor level?
I can see that the consumer unit can be accessed with door open or closed, but what about half way?Well now it is what it is. I could just leave it as the switches are perfectly accessible with only the CU door not being able to close.
I thought of that but I didn't have the height. The people that owned this house before me built a loft which lowered the ceiling in the garage to just above the garage door lintel. My drive also slopes down away from the garage door and I would either have had to lift the ceiling or lower the floor to get a roller door to fit and give me enough headroom.A roller style of door, would have easily fitted in there, and would have been well clear of that consumer unit.
I'd leave it as is if the runners can easily be removed when necessary. Any chance you could modify the CU lid or its fixings slightly to make it removable (but obviously securely closable too)?I could just leave it as the switches are perfectly accessable with only the CU door not being able to close.
