I’m dealing with a frustrating plumbing issue due to what I believe is extremely hard water. I live in a semi-detached house with two bathrooms, both of which use mixer showers connected to a hot water tank.
The issue:
After every single shower, the shower bar gets completely blocked. Very little water is released. I’ve isolated the problem to a small filter mesh inside the shower bar, which gets clogged up with limescale almost immediately after a single use.
This is now happening after every shower in both bathrooms, making it almost unusable. The limescale build-up is that fast and heavy. I’m currently considering a shower filter or water softener, but I’m not sure if that’s a band-aid or the right long-term fix.
Thanks in advance!
The issue:
What I have to do:
- Turn off the mains water supply
- Open up the shower bar
- Remove the limescale build-up on the tiny filter
- Reassemble everything
Setup summary:
- House type: Semi-detached
- Showers: 2 (both mixer type)
- Hot water tank (not combi boiler)
- Hard water area (confirmed)
- Limescale builds inside the shower bar, not just on the shower head
What I need help with:
- Is this a known/common issue in very hard water areas?
- Would a whole-house softener actually stop the issue at the root?
- Are there any specific inline filters that would help before the limescale hits the shower bar?
- Could this be a sign of a bigger problem (like excessive mineral load from the hot tank)?
Thanks in advance!
