Extreme limescale in shower bar
8 Jun 2025
I’m dealing with a frustrating plumbing issue due to what I believe is extremely hard water. I live in a semi-detached house with two bathrooms, both of which use mixer showers connected to a hot water tank.
The issue:
After every single shower, the shower bar gets completely blocked. Very little water is released. I’ve isolated the problem to a small filter mesh inside the shower bar, which gets clogged up with limescale almost immediately after a single use.
What I have to do:​
  • Turn off the mains water supply
  • Open up the shower bar
  • Remove the limescale build-up on the tiny filter
  • Reassemble everything
This is now happening after every shower in both bathrooms, making it almost unusable. The limescale build-up is that fast and heavy. I’m currently considering a shower filter or water softener, but I’m not sure if that’s a band-aid or the right long-term fix.
Setup summary:​
  • House type: Semi-detached
  • Showers: 2 (both mixer type)
  • Hot water tank (not combi boiler)
  • Hard water area (confirmed)
  • Limescale builds inside the shower bar, not just on the shower head
What I need help with:​
  • Is this a known/common issue in very hard water areas?
  • Would a whole-house softener actually stop the issue at the root?
  • Are there any specific inline filters that would help before the limescale hits the shower bar?
  • Could this be a sign of a bigger problem (like excessive mineral load from the hot tank)?
Any advice or suggestions would be hugely appreciated — I’m having to take apart my plumbing almost daily just to have a working shower.
Thanks in advance!
I am from the United Kingdom, Leicester.
I have been living in this property for 5 years but only recently it has become so bad.
A water softener will help going forwards but how long it would take to remove existing limescale from inside the shower heads is another question.
Can you take the shower heads off?
If so put in a suitable container with water and a lot of vinegar
I don't think the issue is with the shower heads. I think it is the shower bar. I have to unscrew the shower bar constantly and remove the limescale from that, which fixes it temporarily.
I forgot to mention an important point. This only ever affects my hot water.
