Most people have to flush multiple times to properly clear solid matter in the pan
thus defeating the aim of mandating 6 litre cisterns, which was to save water.
Yes I have wondered this. They are ceramic, obviously cast from a mould so all kinds of offers could creep in.Its possible you've got a bad casting, especially if it's always been poor at flushing, but the soil pipe doesn't look extra special to me, can you show it a Spirit Level and see what fall there is on it?
Yes, after another look at that almost horizontal SP, I'll lay good odds that there is barely a turn of the bubble to that soil run as it passes through the wall. Without a minimum 3degree fall or thereabouts, the flush will be creating its own backwash in the pipe before it reaches the stack. Somewhat hard to alter at this stage in the WC's history, but as you are considering renewing the lot, a lowering of the stack entry point for the pan could well be the answer to your poor performance flushing problems.I will try and put level on the soil pipe.
Yes I was considering that approach. Might just get enough of an angle. The edge of the pan is 11" from the wall so a bit of space to work with.You could release the making good around the SP where it passes through the wall and then carefully cut a piece of 1" thick ply to raise the pan up 1" and that might just be enuf to encourage the flush to get a hurry on. Other than that, as you said in your last line of your above post.
I think it's a major job to hack out the brickwork to change the angle. Also its two storeys up so not that accessible.Raise the pan; if it solves the problem, you can consider whether to "do it properly" by modifying the hole in the wall. Some users might not like the raised seat.
