I think they all have misinterpreted the regulation; the same as Eric frequently does in stating that ring spurs similarly have a maximum length of three metres.
I think that the infamous OSG trumps Eric for 'interesting' made-up regulations. Can anyone see any sense in (let alone regulatory basis for) ....
On-Site Guide said:
As a rule of thumb for rings, unfused spur lengths should not exceed 1/ 8 the cable length
from the spur to the furthest point of the ring.
The total number of fused spurs is unlimited but the number of non-fused spurs is not to
exceed the total number of socket-outlets and items of stationary equipment connected
directly in the circuit.
No - I mean how do they programme their fuse to ignore the installation faults that they do not want it to cover and for which the customer has to install his own fuse?
Maybe- but (a) regardless of the precise wording, many people seem to think that anything in the OSG is a requirement AND, more to the point, .... (b) can anyone make any sense of the thinking behind the bits I quoted, even if they were only intended as 'recommendations'??
True, but that comes from a document which presents a diagram of "the different parts of a domestic electrical installation" which shows nothing downstream of the "Fuse Unit". That might make EICRs very quick and easy
It's not nonsense from the POV of whether they are allowed to have, and "enforce", a rule which says that you can't have meter tails over a certain length without your own fuse.
Their fuse is theirs, the cables from the meter are yours. They don't have to let you use their fuse to protect your cables if they don't want to.
