Anyone seen this before
I think they all have misinterpreted the regulation; the same as Eric frequently does in stating that ring spurs similarly have a maximum length of three metres.
I think that the infamous OSG trumps Eric for 'interesting' made-up regulations. Can anyone see any sense in (let alone regulatory basis for) ....
On-Site Guide said:
As a rule of thumb for rings, unfused spur lengths should not exceed 1/ 8 the cable length
from the spur to the furthest point of the ring.
The total number of fused spurs is unlimited but the number of non-fused spurs is not to
exceed the total number of socket-outlets and items of stationary equipment connected
directly in the circuit.
Can the DNO alter physics to get you to install an identical fuse that will protect them?
No, but it's their equipment, so they can say how people may or may not use it. Doesn't matter what you or the authors of the Laws of Physics think.
The word "should" rather than "must" tells us the author did not think it was a regulation.
How does that work
Might be written in the T&Cs of the Supply Contract.
EDIT
I can find a reference to this in a guide from National Grid. https://www.nationalgrid.co.uk/downloads/2686
In this they just “recommend” a maximum length of 2 metres.
No - I mean how do they programme their fuse to ignore the installation faults that they do not want it to cover and for which the customer has to install his own fuse?
Care to speculate why?
That does not say another fuse must be added.
Maybe- but (a) regardless of the precise wording, many people seem to think that anything in the OSG is a requirement AND, more to the point, .... (b) can anyone make any sense of the thinking behind the bits I quoted, even if they were only intended as 'recommendations'??
True, but that comes from a document which presents a diagram of "the different parts of a domestic electrical installation" which shows nothing downstream of the "Fuse Unit". That might make EICRs very quick and easy :-)
How does that work?
By having something in the Terms & Conditions which you agree to when you become a customer.
Nonsense.
It's not nonsense from the POV of whether they are allowed to have, and "enforce", a rule which says that you can't have meter tails over a certain length without your own fuse.
Their fuse is theirs, the cables from the meter are yours. They don't have to let you use their fuse to protect your cables if they don't want to.
Do you have to sign and promise that only some of your electricity will used their fuse?
It's not nonsense
Of course it is.
But - how does it work and how does their fuse know.?
But - how do they prevent it being used?
