I'm having an issue with an RCD that keeps tripping as soon as I attempt to turn it back on. I've already unplugged all appliances from the affected circuit, but the RCD still trips immediately. To isolate the fault, I disconnected each socket on the circuit one by one and managed to trace the problem to a single socket.
When this socket is disconnected, the RCD resets without any issue. However, when I install a brand new socket in its place and wire it up, the RCD trips again as soon as I attempt to turn it on.
This suggests the issue might not be the socket itself but potentially a fault in the cable feeding it. There are no obvious signs of damage, but I haven’t carried out any insulation resistance testing yet.
Looking for advice or confirmation from anyone who's seen a similar issue — is it likely to be a neutral-to-earth fault or some other wiring issue in the cable?
