- Joined
- 7 Sep 2022
- Messages
- 4,927
- Reaction score
- 1,432
- Country
Take the screw you plan to wind in and hold it next to the drill bit so the tip of the screw and the tip of the drill bit are next to each other, then move the screw at least 5 mm towards the drill (away from the point of the drill bit). Wrap electrical tape around the drill bit next to where the head is
Now drill your wall until the electrical tape is just about to touch the wall surface. You have now drilled a hole 5mm deeper than the screw is long, so you won't encounter any issues with the screw bottoming out/not winding all the way flush
Be mindful of the wall construction too; if there is a thick layer of soft plaster (assess it as you drill) on the wall before you get to the harder brick/stone then you'll need to drill all the way through that, so you'll need to add on the thickness of the plaster when tape marking the bit. To get the plug past the soft plaster part you can use the screw itself, plus a hammer to tap the plug down into the hole. Remember that you'll need longer screws, and also maybe thicker screws if they will have something heavy on them, bending them (the plaster part of the wall won't offer much support) ; the fixings you choose will depend on how the item you're fixing is used, what loads it experiences in service, and whether those loads strive to slide down the wall, pull away from the wall etc
Nearly 100% of the time that you buy something, it will come with the crappiest screws and plugs you will ever find. Bin them without even trying to use them, and keep a stock of decent plugs and screws
Make sure you're using the right screwdriver bit for the screws you have. Just because they're a + shape doesn't not mean they're designed to go together. If you have PH screws, use PH a bit of the right size. If you have PZ screws, use a PZ bit of the right size. Generally the screws you will use for mounting things will be PZ, and the + shape in the end of them will have an x shape overlaid on it. PZ bits look more aggressive than PH bits, with extra sharp vanes between the + shape that drives the screw
In the pic above the correct bit for the correct screw are touching each other. Don't mix the types, unless you're really competent. Newbies that mix the wrong bit and screw typically end up destroying the bit, the screw or stabbing themselves in the finger with the driver
To clear the hole, insert a straw and blow down it, but shut your eyes before you blow
