Is that a caveat for the weight increases temporarily on the supports?(once things had levelled out)
I suspect a typo here, 20k cube weighs 20,000 tons, which would have a different effect on the weight of the system than a 2,000 ton barge, but I agree with the spirit of what you say.If you craned a barge into the canal, which had a total mass of say 2kT, then the effect would be exactly the same (once things had levelled out) as if you'd poured 20k cubic metres of water into the canal
The weight increases permanently on the supports. The system as a whole weighs more and all parts of it must share the load out. If you drop that barge causing a huge splash and resulting wave, the weight borne by the bridge increases more as it carries the wave, then less than it as the wave passes (the height lowers to less than the sitting water line was before) then more than it was as the level refills and so on until equilibrium is restored.Is that a caveat for the weight increases temporarily on the supports?
So the physics graduate was correct then.The weight increases permanently on the supports.
Well, your question seemed to be more about a barge that is already in the system and contributing to the weight already, being sailed over the bridge - does the weight experienced by the bridge increase for the time the barge passes over? No, not in the sense i suspect you're asking. The system already weighs X tons, of barge plus water, and if you can move the barge around so you don't cause water to pile up somewhere then there is no local increase in weight.So the physics graduate was correct then.
Nah, more fun to just let folk run with it.Need to be really specific about the parameters of the question
I suppose there will be modest increases with things like wind loading or some such.- if to you even a microgram of increase in weight on the bridge supports is "yes the bridge supports are carrying more" then it's yes, because it's practically impossible to move the boat without disturbing the water.
If the threshold is "do the bridge supports experience an increase of 20 tons?" then it's no (unless you can move that boat in such a way that you ramp 20 cubic metres of water up against it as it goes, no small feat)
Well, there is that "drop a smoke bomb into a crowded room" effectNah, more fun to just let folk run with it.
Indubitably, though in the interest of getting a quick answer hay's good enough we normally choose to omit stuff like that, with careful wording such as:I suppose there will be modest increases with things like wind loading or some such.
Often questions of any kind are half baked and aren't really well specified enough to give a clear and definitive answer but people interpret it in their own way and then start arguing over the differences in two interpretations (interpretatiae?) but if that's the aim then I don't suppose we'll get you to refine the question any. Surprised the physics grad didn't go through all that with you (or maybe they did)
A bucket of negligible weight and holding 10L of water is sat on..
and other such that lets the answerer know they shouldn't factor the weight of the bucket, change in mass due to evaporation of the water during the time taken for the experiment to be conducted, and other such impossible-to-arrange factors
A truck weighing exactly ten tons drives onto a mile long bridge, that can only support exactly ten tons. Half way along the driver stops and gets out. A sparrow weighing 30g lands on the truck
Does the bridge collapse?
Once upon a time the answer was fairly clear but these days there is now an important factor omitted that changes the outcome completely. More questions are required before it can be answered
A bit of fun
The original question was does the weight of the barge increase the weight pressing down onto the aqueducts legs. No it doesn’t. You moved the goalposts and went into an entirely different question. I would say a typical noseall question wanting his usual drama.
A bit of fun
I was responding to Highway man who suffers from changes in atmospheric pressure as he works from height.No, atmospheric pressure is the same
Let me guess someone tied you to a helium balloon to help you get up.I was just out walking in the street and was pushed to the ground as the weight of the 400 ton Boeing 747 flew over me .![]()
