I've heard strongly conflicting versions of that, t'other being having the light by the window simulated the natural light coming in through the window.
I have heard that version too.
I reckon a 50:50 split IME. Years ago I had a book from 1920's titled something like 'Modern Wiring Practices', I think it was that gave the daylight version and debunked the shadow version as curtains are thick enough to prevent the effect.Same here - but,as I wrote, I've often heard the 'explanation' you suggested (silhouettes/shadows on curtains)
Who knows?! Curtains obviously vary a lot, and I don't think that there are (m)any in my present house which are thick/'lightproof' enough to 'prevent the effect'!I reckon a 50:50 split IME. Years ago I had a book from 1920's titled something like 'Modern Wiring Practices', I think it was that gave the daylight version and debunked the shadow version as curtains are thick enough to prevent the effect.
Yes I have often considered that too especially in W W 2 I would imaginedebunked the shadow version as curtains are thick enough to prevent the effect.
I would.I think morqthana would call that 'upside down' :-1)
All 3 with the bulk of the body at the top, although of course the 2-pin one can be plugged into its adapter either way up. I wonder, if it was plugged in oriented as per the photo, would it fit below the cupboard?
Looks pretty tight.
When plugged in the writing is the right way up, what is upside down about it?I would.I think morqthana would call that 'upside down' :-1)
They are all similar 3 pin devices and all fit into those sockets with ease.View attachment 385783All 3 with the bulk of the body at the top, although of course the 2-pin one can be plugged into its adapter either way up. I wonder, if it was plugged in oriented as per the photo, would it fit below the cupboard?
Just perspective, my fingers pass above that.View attachment 385784
Looks pretty tight.
I'm sure you must understand what he meant, particularly given that the reason for his comment was, in context, obvious ...When plugged in the writing is the right way up, what is upside down about it?
We do, but, in relation to 'the big picture', and for whatever reason, currencies (£, $, € etc.) seem to be a rare exception to the general rule/convention that the specifier of 'units' usually comes after the numerical value concerned.Mind you we have always written five pounds sterling as £5 not 5£ ...
That's because it is not actually clear what is meant.It reminds me of sq inches and inches square etc (inc sqmm and mmsq) is not what we are taught in maths is it?
As EFLI has implied, I don't think that "inches square" is actually a legitimate term. As I think he is saying, "inches squared" is legitimate, and has the same meaning as "square inches".It reminds me of sq inches and inches square etc (inc sqmm and mmsq) is not what we are taught in maths is it?
Not sure I would go that far. It depends what one is meaning.As EFLI has implied, I don't think that "inches square" is actually a legitimate term.
Yes - with the 'd'.As I think he is saying, "inches squared" is legitimate, and has the same meaning as "square inches".
Yes, agreed. I probably wasn't clear enough - what I meant is that "inches square" is not a legitimate unit. (whereas "inches "squared" or "square inches" is)Not sure I would go that far. It depends what one is meaning. ... I think. for example, "4 inches square" is when something is 4" x 4"; therefore 16 square inches.
As above, other than 'completely in error', I don't think that people ever use the version without the "d" as a unit.Yes - with the 'd'. However - people do not distinguish between the meanings.
Well, no. It is not a unit.Yes, agreed. I probably wasn't clear enough - what I meant is that "inches square" is not a legitimate unit. (whereas "inches "squared" or "square inches" is)
Ok? Do you mean they don't ever do that except when they are wrong?As above, other than 'completely in error', I don't think that people ever use the version without the "d" as a unit.
