Why not?Any MCB (Miniature Circuit Braker) (or RCBO) rated at 32 A (or there abouts) is almost certainly protecting a Ring circuit.
which really should not be used installed or upgraded - in this "day and age".
Rings are allowed, nothing has changed.I haven't watched it, so rings aren't allowed anymore?
Cut in in half and make it into 2 radials.considering the op already has a ring circuit what you gonna do
So someone asking to add one extra socket you would tell them to replace the 32 amp mcb with 2 x 20 amp mcbs, (if there is even space)find the middle then split it, then add the socket? OK.Cut in in half and make it into 2 radials.
You can't use the term "live" in that context - even if it is a Don't DIY (DIY NOT) forum - as the term literally has a meaning which is different to how it is being misused.we know that you live in a foreign country (or do you).
But please remember the first three letters of this forum: DIY
Pedantry will have a number of effects. Mainly confusing those whose grasp on electrical things isnt at professor level to the point where they give up and go away. Which rather defeats the point of the forum, don't you think?
The first one minute of this video indicates that,I haven't watched it, so rings aren't allowed anymore?
Just because the presenter has a personal opinion does not make that a fact.the presenter does not think that they are a good idea.
In Electricity more than most. It will always happenThings do go off track on here
