Mind blown !
Why would anyone need to take a reading? My station records all the values, every few seconds, saves them to a file, and also uploads them to the Met Office. I can go back through the file on my system for years, have it check for maximum/minimum/averages. I can log in to my data on the Met Office site and do similar.
Interesting so does that mean you are you part of the met office statistics then.
You completely wasted your time researching and calculating because you ignored what I said. That "road" that go's by the weather station is a transit route to the bottom of the runway - every one that takes trundles right past it -close to it.
So virtually no heat from the engines, cool. Even less than 0.04 degrees.
Probably - I dont know but I am not sure your fag packet calculations prove either way. Seems to me that the weather station is in a bad position all around, but then.
The WMO explicitly states you shouldn't reject weather reports using a lower tier of station as perfection isn't required.
Because it's not your job and you consume poor quality news that makes you distrust it.
The met office has been doing this stuff for hundreds of years.
All very interesting developments over the last 3 pages - amazing how a querie about a red brick wall in a garden can grow :)
That's why the highest temps used to scaremonger climate change doomers are situated in concrete jungle heat islands like the Coningsby RAF air base and Heathrow airport.
Utter bolox
That was proven bolox on the other thread.
Please can you stop posting misinformation.
If you wish to post misinformation, go and find an echo chamber of like minded w@nkers
The same weather station has been recording temperatures for donkeys years.
And the temps keep going up
So that’s your childish nonsense in the bin.
Please leave this forum, we do not need your type here.
Bye bye
Utter bolox
like minded w@nkers
childish nonsense
Oh here he is - he's back again - you know this forum was a pleasant place without you here - no one swore at each other everyone listened to each others points and we had a polite enough conversation about stuff. Have you learned nothing from your ban. You need to work on your manners.
:ROFLMAO::ROFLMAO::ROFLMAO:
:ROFLMAO::ROFLMAO:
:ROFLMAO:
