There's no such thing as kW per hour
Sure there is. I already tried to explain it. It relates to changing power. "This charger is 100kW but it doesn't turn that on all at once, it slowly increases the power offered over time, and the rate of change is 25kW/hour. If you set it going now, in 4 hours' time it will be at full power"
Though kW per hour is a valid descriptor of something, it is not a valid descriptor of anything here
But that's OK. Your words were "kW
h per hour", not "kW per hour"
You absolutely can add x number of kWh per hour of charging
Yep. Never said you couldn't. A charger that adds 22kWh of fuel to a car, per hour, is a 22kW charger.
Remember, your words were "
kWh in an hour - NOT kW" and I merely pointed out they were the same thing. Here we are, N posts later you still playing fast and loose with units, twisting things for reasons I cannot fathom
Gas lights are fossil fuel based. This discussion is entirely about the next generation of motive fuel
Let's have a recap
kWh - an amount of energy
kW - a rate of flow of energy
kWh/h - a rate of flow of energy. No one talks about this in charge terms, they just say kW instead
kW/h - a rate of change of a rate of flow of energy. No one talks about this in charger terms, but they could
