Masonry multitool blades
18 Apr 2022
Any good? Are some good-er than others?
I've got to cut some holes for socket back boxes, into brick or deep-joy-breeze-block. I'll stitch drill and use a bolster and hammer to remove the bulk, but I'd like to trim the edges with a blade so as to (fingers crossed) avoid any making good to the wall.
i have just put a load of sockets into aerated breeze block and very hard brick
for the channel - i used a grinder in the end
BUT for the backbox - I used a grinder (diamond blade to get the top/bottom and sides - roughly and then i used the multitool - to cut the rest out and SDS drill/chisel to cut the bult out
carbide coated
BUT just a DIYer - not an existing trade sparky - so you may want to wait for their answer
I don't need to cut a chase for the cable - basically I'm putting in larger boxes in existing locations.
I don't have an angle grinder, but even if I did I'd not want to use it 'cos of the mess.
Carbide, or diamond?
Or if you are just swopping to twin from single?
OMG yes, the mess would be everywhere.
The ness isn't horrific if you hold a running vacuum cleaner so as to suck all the output dust from the cut where the blade exits the substrate.
A slower running battery grinder helps too, and you can get dedicated cutters that have a housing that goes over the entire cut and has a dust extractor attachment
What's the requirement for deeper boxes driven by?
Yep, thats what i do - in fact have 2 Vacs going as i happen to have 2 and as you say mine is a Battery Dewalt grinder
We put tarpaulin over sone items in the room - as i had to so 12 boxes in all it was worth it - probably not for 1 or 2
I put in some of the triple back boxes and single row euromodules as well as some single & double backboxes - spurs and isolator switched
was worth it as much faster and not that deep as the room was going to be plasterboarded anyway
I have only used the carbide blades and would not want to cut a box out with them -
They do make Diamond , but never used , the service dept staff are very good and helped me with a few blade types for multitool and also for my Mitresaw and circular saw
I have used Saxton diamond blades to enlarge cracks in particularly hard external render. They became blunt so quickly that I resorted to using an angle grinder (with a vacuum hose next to it).
From memory, each blade lasted about 7 minutes.
I was so unimpressed that the next time I need to do that for a customer, I will purchase a smaller/mini angle grinder in the hope that, when working off a ladder it will be easier to work with.
