- Joined
- 18 Nov 2003
- Messages
- 111
- Reaction score
- 6
- Country
Ok so after many years of putting up with scruffy t&e cable coming out of the wall below kitchen wall cupboards which fed the under cabinet lamps: I decided it was time to route it behind the plaster board to exit above the wall cabinets and be out of sight.
The cable (marked red in the attached pic) needs to be extended so I plan to join it with Wagos and fix it into a wago light box behind the plasterboard. On cutting the access hole I found another cable (marked green) unattached to anything and not terminated in any way.
The cable is, or looks like 1mm t&e, I find it difficult to tell the difference between 1 and 1.5. I've tried to find out where this cable comes from and I can't; I can't get it to be live, I've tried all light switches and nothing makes it live, Ive also checked all of the plug sockets to see if it could have been attached as a spur cable even though I would guess that the cable is too small for that; I'm a bit stumped and although it appears to be a dead cable I don't feel comfortable just stuffing it back behind the plasterboard, so really just looking for some reassurance that, If i terminate it in a wago box that would be fine.
The house is a bout 8 years old and we were the first owners so no chance of any previous diy jiggery pokery and I'm lost as to why this cable is even there.
One other question; the cooker hood fcu is supplied by what seems like 1 or 1.5mm t&e and is on the ground floor lighting circuit breaker; is this normal practice?
Thanks in advance
Thanks in advance
