- Joined
- 27 Jan 2008
- Messages
- 28,977
- Reaction score
- 3,551
- Location
- Country
Solar panels don't work like that. If you look at yesterday, for exampleduring the day when you panels are generating power turn your immersion heater on
the solar exceeded 3 kW for a very short time, and I have panels rated at 6 kW, so the likes of the iboost+ have a CT coil that monitors how much is being supplied to the grid, and it controls how much power goes into the water to match how much is being generated, so it may be only using 200 watt to heat the water at times, it does not need the export to hit 3 kW before is switches on.The likes of the iboost+ were designed when export was assumed, rather than measured, and still can be useful for people who are not paid for export, or paid very little for export. But I get 15p/kWh for export, and pay 8.5p/kWh for off-peak, so I would be better off with a simple time switch, that heats the DHW with off-peak to the complex iboost+ I have fitted. However, the gain is not enough to be worth changing it.
Some tariffs there still is a slight gain using solar rather than off-peak, but it would also depend on time of the day,
the rates shown here can't be programmed into my iboost+ but there are some other makes, which can be programmed, but at these prices If my iboost+ were to fail, I would not replace it, but would use a simple time switch instead. However, unless you have a smart meter, you can't have a split tariff, only those who had Economy 7 before the smart meter came out, can continue to have a time clock to change rates, and to be frank the Economy 7 and Economy 10 rates were not that good, it seems if you have enough money to buy an EV car you can have some very good rates, but if you're stuck with the old storage heaters, tough, they already have you're custom, you can pay extra for your power.
