- Joined
- 7 Sep 2022
- Messages
- 4,492
- Reaction score
- 1,288
- Country
I'm not a fan of PIV, as a concept; "let's encourage people to install a fan that brings air in, slightly pressurising the house so that moist stale air is pushed into the gaps/cracks in the building fabric"Would that be a PIV?
I'm referring to MVHR; two fans in a box, cleverly arranged so they push air through a heat exchanger; the warm stale air from the house is used to heat up the cool fresh air from outside, resulting in a supply of warm fresh air to the house and cool stale air expelled. The air flows never mix, but they pass by each other, separated by a very thin wall so the heat passes across.
If it manages to recover 90% of the heat in the stale air, then you only need to run your heating at a low level to replenish the 10% of heat lost to outside.
PIV on the other hand, as well as pushing moisture into the building fabric doesn't naturally recover any of the heat so all of the heat energy you paid for, in the air that escapes the envelope of the house, must be paid for again
MVHR are amazing, and I will never again live in a house without one, but they are a bit trickier to fit as a retro compared to doing it when a house is being constructed. They're also relatively expensive, but it is hands down one of the best things I fitted to my house and so to me they represent great value for money. The house is seldom stuffy or smelly; "no more farty bedrooms" is usually an easy way to win over the lady decision maker
