belt or chain drive for oil pump?
I've got a multi metre. Never done glow plugs though
The first one says DTC definition not found refer to vehicle service manual.
IMO if your code reader interface has not been fully recognised by the vehicle's system, you can't rely on the codes that are displayed being correct.Sorry for the delay. It now says 1 fault and 1 pending.
Interesting. I wonder, if it's that, how much it'd cost cost in a garage. I'm surprised it's not running hot already.Google AI - fault with coolant pump, wiring , circuit or pump
I just mean if it's complicated and that's the problem. I'll get the under cover off tomorrow if I get the chance. I only put it on last week and it tricky if you're working on the floor.Why wonder? Climb under, and take a look! If the wire has failed, try joining it with connectors, if that fault can then be cleared - time to make a more permanent repair.
